Sponsored by: CARiD
Timing cover gasket repair gone bad
Old Feb 20, 2014 | 07:48 AM
Disconeer's Avatar
6th Gear
Default Timing cover gasket repair gone bad
All -
I attempted my first major repair this week. The gasket of the timing cover was leaking. Local mechanic wanted $1200 so I decided to tackle this beast on my own. I thought the repair went well but upon first cranking, I have found that there is oil leaking from around the timing cover seal (crank shaft seal). I put a new seal in and everything seemed to go back together well. What could have gone wrong?
Is the new seal supposed to be flush with the outside of the cover or be pushed in until it stops (slightly recessed)?
Any ideas?
I also found a small leak in the top of the radiator that seems to be a pinhole in the plastic and there is also antifreeze leaking from the shroud screw hole. I guess this means radiator replacement too.
Thanks.
Old Feb 24, 2014 | 11:44 AM
Disconeer's Avatar
6th Gear
Bump. Need a little help here guys. Anyone? Bueler? Please?
Old Feb 24, 2014 | 01:04 PM
Crash_Control's Avatar
6th Gear
Did you pack the back side of the seal with chassis grease to keep the seal spring in place when you installed the seal in the housing ?
Did you oil the lip of the seal so the crank pulley won't rip the seal ?
Old Feb 25, 2014 | 08:42 AM
antichrist's Avatar
Also the crank pulley land where the seal rides can get grooved by the old seal. If that happens a the seal will likely leak and you'll need to fit a Speedy Sleeve.
A5scott
Jul 11, 2015 07:25 PM
outdoor7or24
Dec 22, 2014 09:31 PM
BradyBug
Jun 19, 2014 07:09 PM
azoverlander
Sep 17, 2009 11:53 PM
