Sponsored by: CARiD
tire size question
Old Sep 22, 2009 | 12:32 AM
MountainOx's Avatar
Default tire size question
my question is: on my 92 range rover classic i am looking into buying some off road tires. would i be able to run either one of these tire sizes on my stock 24spline axles? i also put the specs of the tires as well, probly not needed but figured i would.
285/75R16
Load Index 122 = 3368lbs (1531kg) per tire
Load Index 119 = 3074lbs ( 1397kg) per tire
Speed Rating “Q” = 99mph (160kph) 122/119Q
D Standard Sidewall Not required for
this tire.None
3605 lbs.
65 psi
15/32"
52 lbs. 0-0"
8"
11.3"
NA
32.8"
315/75R16
Load Index 121 = 3267lbs (1485kg) per tire
Speed Rating “Q” = 99mph (160kph) 121Q
this tire.None
3195 lbs.
50 psi
15/32"
67 lbs. 8-10"
8.5"
12.3"
NA
34.6"
i use my rover on the trail. i have a set of sock sized mud terain tires but i am lookng for some more axle clearance an ground clearance. i have a 4inch lift on my 92 range rover.
mtnmac82
Oct 8, 2009 05:17 PM
sixthflick
May 24, 2009 12:11 AM
flyplanes5
Nov 2, 2008 08:30 PM
jwood700
Oct 28, 2008 05:53 PM
ajh
Oct 23, 2007 10:13 AM
