Transfer case locked or unlocked?
I have a 2000 Discovery II. The transfer case was locked after the front drive shaft was taken out for replacement. I just installed the new drive shaft but are not sure if the case is still locked after I turned a short distance. Is there a way to tell if it is fully locked or unlocked?
Mine did not have a light on the dash before. I also had to turn the nut from the top of the transfer case. Is there a way to tell by the way the wheels turn when jacked up? I drove around a couple of days before the person I bought it from called me and said he had locked it before the drive shaft was removed. I could not tell a difference either way.
lesley1
01-25-2009 10:15 AM
meseun
Audio/Visual Electronics
08-24-2006 07:53 AM
midways
08-10-2006 03:56 PM
