Sponsored by: CARiD
Transfer case locked or unlocked?
Old Apr 7, 2010 | 05:45 PM
All4uonline's Avatar
6th Gear
Default Transfer case locked or unlocked?
I have a 2000 Discovery II. The transfer case was locked after the front drive shaft was taken out for replacement. I just installed the new drive shaft but are not sure if the case is still locked after I turned a short distance. Is there a way to tell if it is fully locked or unlocked?
Old Apr 7, 2010 | 07:41 PM
Back and to the right is unlocked normal position.
There is a light on the dash that looks like gears, that light should be off.
Old Apr 7, 2010 | 08:35 PM
6th Gear
Mine did not have a light on the dash before. I also had to turn the nut from the top of the transfer case. Is there a way to tell by the way the wheels turn when jacked up? I drove around a couple of days before the person I bought it from called me and said he had locked it before the drive shaft was removed. I could not tell a difference either way.
Old Apr 14, 2010 | 08:40 AM
Turn the CDL nipple full counter clock wise and that will disengage the t/case.
Old Apr 19, 2010 | 05:43 PM
6th Gear
thanks mike. got it.
Big Jim Swade
Nov 16, 2013 10:00 PM
Lord Wert
Mar 27, 2013 06:50 AM
lesley1
Jan 25, 2009 10:15 AM
meseun
Audio/Visual Electronics
Aug 24, 2006 07:53 AM
midways
Aug 10, 2006 03:56 PM
