Sponsored by: CARiD
transmission no go, lock differential, yes
Old May 20, 2009 | 12:04 AM
ddabster's Avatar
3rd Gear
Default transmission no go, lock differential, yes
96 discovery been in family couple of years. runs great, slipped once last week when I put it in park. I checked trany fluid, barely low, topped it off. That was Fri. Sunday, drove about 30 miles to church and back. Parked and seemed all was fine. Then like a teenage daughter where all was okay a moment ago and then, "Good Lord, what was that all about!" kind of deal. It moved about 3 feet Mon morning and that was it. It drives with differential locked, but not just the transmission. It will not engage. HELP!
Old May 20, 2009 | 08:52 AM
I would suggest you PM me your tele number so I can walk you thru what to test for.
You have broken either a CV joint or diff.
Old May 21, 2009 | 01:52 PM
antichrist's Avatar
Just pull both axles, you have to pull them anyway to replace the diff.
If one CV is broken my advice is to replace both since they were both likely strained to near the breaking point, and one did break.
If both axles are ok, then the problem is your diff and you need to pull that and go from there.
Old May 27, 2009 | 12:57 AM
batateam's Avatar
I checked trany fluid, barely new york asian escort low, topped it off. That was Fri. Sunday, drove about 30 miles to church and back. Parked new york asian escorts and seemed all was fine. Then like a teenage daughter where all was okay a moment ago and then, "Good Lord, what was that all about!" kind of deal. It moved about 3 feet new york escort Mon morning and that was it. It drives with differential locked, but new york escorts not just the transmission. It will not engage. HELP!
collin Barrows
Audio/Visual Electronics
Aug 21, 2011 12:47 PM
tskeltonPGA
Jan 16, 2008 07:21 PM
audiurq
Jul 1, 2007 11:52 PM
tailchaser0527
Mar 5, 2007 06:23 PM
toxico
Oct 20, 2005 02:15 PM
