trouble codes
trouble codes
Hello to all,ive got a huge prob with disco,need to get inspected service engine light came on,had scanned 1174,1171,1590,0174,0150,0300,0307,holly crap,replaced both front 02 sensors already clear codes,they return less then 20 miles,cleaned maf sensor with carb clean,off of course,seems like all these codes at one time is odd,leaning towards replacing MAF,any help will be appreciated.
on
First, the carb cleaner, which you never use on a MAF, will kill it.
The front 02 is dead which is causing you a lot of grief and your 1590 is a rough road/ABS fault code.
Check and make sure your 02 sensors connections are oil free, if they are contact whoever you bought the 02's from and get it warrantied.
