Sponsored by: CARiD
Tyre Pressures
Old Feb 22, 2005 | 09:25 PM
englishboyonice's Avatar
Default Tyre Pressures
I have these tyre on my 98 discovery: 31x10.50R15LT winter tyres
Anyone know what the tyre pressures should be for these on a 98 Disco I?
The manual has info about smaller ones but they alway put bigger ones on here in Iceland.
Thank you in advance!!
Old Feb 23, 2005 | 02:00 AM
Bene's Avatar
Default RE: Tyre Pressures
i think normaly, the recomended psi is written on the sidewall. if not i i think most tires are 30 - 35 psi. see how that suits you.
Old Feb 23, 2005 | 04:04 AM
Lighting90's Avatar
I think it is 30 at the front and 35 at the rear.. but generally as Bene says, should be in this area anyway...
Though as your in ICeland, you may need to run as low as 5psi in some situations..
Old Feb 26, 2005 | 03:31 AM
Bene's Avatar
if i gets to the point where you're changing the tire presure a lot, i would consider one of those on board air compressors.
Old Mar 29, 2005 | 07:31 PM
mikemeyer0's Avatar
30-35psi (not kpa) in front and rear, but both front and rear should be the same.
IvanC55
Oct 28, 2014 11:42 PM
lipadj46
Mar 16, 2012 04:51 PM
pilsner
Jun 24, 2009 09:30 AM
kpxus
May 13, 2006 08:13 PM
englishboyonice
Feb 23, 2005 04:04 AM
