I was pulling my injectors today to clean them. Dang things are seized in the engine. I slowly pull the injectors up and out with some force needed. I finally get the rail out with all four injectors only to see that a couple O-rings are still in the engine. After further investigating I see that two of the injectors are missing a little rubber things below the bottom O-ring. I searched in the hole and around it but I can not find this little rubber thing. I modified a vacuum with a cut piece of air hose and tried to suck the part out. This was unsuccessful. Tried using compressed air to move the part around. This was unsuccessful. What do I do? Currently four of these plastic parts are in the engine. Think they will just burn up if I run it.
O-rings stuck in rail O-rings stuck Injectors missing parts Dirty injector missing part
Here’s the little A-hole that dropped into the engine.
Hi, it’s an ‘05 LR3 with 160k. I did post on the LR3 forum… but I figure this is a general inquiry. I’m starting to think I should pull the intake manifold. Curious if this has happened to anyone else and what they ended up doing.
