Sponsored by: CARiD
Water leak to the interior, where’s it coming from?!
Old Nov 23, 2024 | 08:46 PM
Redline870's Avatar
Default Water leak to the interior, where’s it coming from?!
I’m getting water pooling in the RR area of my 2015 LR4. The RR corner is the lowest point when parked on my driveway, but where the heck is it coming from? Any ideas? It appears to be coming from the base of the B pillar or somewhere in that vicinity. Thanks for your time!
Old Nov 24, 2024 | 07:50 AM
Redline870's Avatar
Upon further inspection, it may be coming from the RF A pillar area and running all the way back, because there’s a damp spot right next to the kick panel on the floor.
Old Nov 24, 2024 | 10:38 AM
Elzot's Avatar
windshield leaks are a known problem. I suggest parking in a level spot and hosing around the windshield and checking.
Old Nov 26, 2024 | 07:39 AM
Redline870's Avatar
any spot in particular that I should pay close attention to?
Old Nov 26, 2024 | 07:44 AM
WaltNYC's Avatar
could also be a clogged/fouled sunroof drain. You will likely need to drop the headliner to see what is up.
Old Nov 26, 2024 | 11:26 AM
Elzot's Avatar
Mine was leaking along the top driver's side. But, the issue is the application of the glue in the factory, so it could be anywhere along the edges of the windshield.
Aislinn McAuley
Sights N Sounds
May 12, 2023 01:46 PM
HatManSan
Discovery Sport
Dec 18, 2021 04:11 PM
Zwyde
LR4
Apr 30, 2021 08:01 AM
nashvegas
Dec 31, 2020 12:01 AM
nelbra
Jun 27, 2010 09:40 PM
