Water Leak On Passenger Side
Old Apr 30, 2021 | 03:27 AM
Zwyde's Avatar
8th Gear
Default Water Leak On Passenger Side
Good day. I just experienced a leak on the passenger side from the top balancing handle (see attached images). Has anyone experienced this? Any suggestions where to look for the leak?
Thank you.
2010 Landrover Discovery |
3.0 TDV6 SE | 171,700KM
Old Apr 30, 2021 | 04:17 AM
jeffh's Avatar
Sunroof drain line needs to be cleaned or replaced. There is a cache in the roof that gets all clogged as well. you can try to clean the whole line with an air burst from the bottom of the drain line. but be careful.
Old Apr 30, 2021 | 07:05 AM
Wilybyrd's Avatar
Some weed trimmer line can also be used to unclog small amounts of debris and flush it out with water. The issue could also be clip seals on the A-pillar trim. Land Rover has a TSB about it and kits to replace the trim clips and seals can be found online.
Wilybyrd
'10 LR4 HSE
Old Apr 30, 2021 | 08:01 AM
Zwyde's Avatar
8th Gear
Thank you all for your responses. Managed to unclog the drain pipe on the passenger side. Tested and seems to be draining ok. Will wait and see after driving in the rain again.
nashvegas
Jan 2, 2021 07:39 PM
cvhyatt
Jan 26, 2020 02:05 PM
nelbra
Jun 27, 2010 09:40 PM
wblake
Oct 21, 2007 09:30 AM
luckydog
Oct 12, 2006 04:35 PM
