Sponsored by: CARiD
Water pump/pulley issue
Old Sep 12, 2024 | 01:09 AM
DiscoBenny's Avatar
Default Water pump/pulley issue
2002 D2 broke down today, I think it's the water pump. Pulley broke off. Immediate loss of power steering, battery light came on, and started overheating within 2 minutes.
I'm assuming it needs a new water pump, unless it's possible to just replace the pulley wheel? Curious how difficult a job this should be? I'm pretty amateur but would love to do it myself if possible. How difficult to replace the pump and belt?
Old Sep 12, 2024 | 09:03 AM
mollusc's Avatar
1. Post D2 issues in the D2 forum.
2. The water pump is replaced as a whole unit. Pretty simple job.
3. That's the tensioner pulley, not the water pump. You need to replace that whole assembly.
Old Sep 12, 2024 | 02:46 PM
Harvlr's Avatar
Tensioner replacement is easy. I hope you didn’t overheat your engine. Two minutes is way too long to be running without the water pump turning. As said above, post this in the D2 section of the forum.
Old Sep 20, 2024 | 12:05 PM
Best4x4's Avatar
You can get a metal tensioner pulley vs plastic.
Brandon318
Jan 6, 2025 07:30 PM
Greg_M
Mar 23, 2023 08:02 PM
CaptainAaron
Jun 22, 2022 09:02 AM
Matt Humes
Jun 20, 2019 08:45 AM
guywithadisco
Aug 18, 2009 07:15 PM
