Sponsored by: CARiD
This is weird and challenging
Old Feb 20, 2017 | 09:05 PM
Mr. Clover's Avatar
Exclamation This is weird and challenging
Hello Land Rover Brothers and Sisters!
So my 03 LR Disc. II keeps lighting up my Check Engine light, my TC light, my ABS light and my downhill brake light. Yet the engine seems to be running fine. Anyone know what the heck is going on?
Thanks!
Scott
Old Feb 20, 2017 | 09:14 PM
KernowDiscovery's Avatar
Hi there!
Sounds as if you may have the dreaded 3 amigos plus your check engine light is on. Do a search on 3 amigos - sometimes it's due to an ABS sensor gone bad. There are workarounds to it. I haven't done anything with mine yet (need gumption?), anyway, the only thing it appears to affect is your anti-lock braking system (which is useful if you try to stop on ice as I do in the winter).
Check your codes to see what is causing the 'check engine light' to be lit. If you don't have an OBDII reader (ultragauge, etc.), you can stop at an auto parts store (ie; autozone) and they can read the codes for you. I had mine light up in the past due to a bad gas cap so it could be something simple like that.
Good luck and let us know what you find
Christina
Atlrover89
Jan 11, 2016 06:55 AM
nicklaeena
Jan 25, 2013 01:32 PM
Darover
Dec 17, 2008 07:54 PM
chig
Jul 21, 2008 02:33 PM
rravenn13
Oct 3, 2007 03:28 PM
