Sponsored by: CARiD
Winding noise in front diff
Old Jan 25, 2011 | 05:46 AM
Jdar's Avatar
4th Gear
Default Winding noise in front diff
Curious to see if anyone has had a similar problem?
I run a 300 tdi defender and have noticed a winding noise coming from the front diff, especially in the straight through gear of 4th.
I have sought advice from a certain company up here and they suggested that it was the gear box and were adamant on their diagnosis but they were wrong.
I am aware that at 215000 k's there may be wear in the crown wheel and pinion and possibly the movement is making the noise.
My solution will be based around putting in a diff locker in the front and possibly the back. Should i purchase a 24 spline diff and just replace the lot?
Your help would be much appreciated.
Also has anyone been running 33x315x75 tyres?
I am wondering if they may be a little too big for the engine
Old Jan 26, 2011 | 07:58 PM
Sounds like classic failing diff noise to me.
Old Jan 28, 2011 | 02:08 AM
Jdar's Avatar
4th Gear
What would be the best way to help the failing diff
Old Jan 30, 2011 | 06:51 PM
To replace it.
Old Jan 30, 2011 | 07:37 PM
antichrist's Avatar
If you're installing lockers I'd get heavier duty axles.
Old Jan 31, 2011 | 08:52 AM
Jdar's Avatar
4th Gear
Why would I need to upgrade the axle? What experiences have been noted? Apart from the obvious breaking.
Perhaps with a wider footprint there could be a greater need for the upgrade also.
Any tips on a good supplier?
FlyingZebra34
Dec 22, 2012 04:15 PM
DiscoRover007
Sep 29, 2011 07:41 PM
rambo
Jan 18, 2009 05:52 PM
Disco2Guy
Jun 20, 2008 10:13 PM
jvanbelkum
Oct 22, 2007 02:20 PM
