Sponsored by: CARiD
97 Discovery SE7 Winding sound
Old Nov 4, 2004 | 03:40 PM
jvanbelkum's Avatar
4th Gear
Default 97 Discovery SE7 Winding sound
I have noticed a winding sound that increases and decreases with speed on my 97 Disc. SE7. Tires are
new and didn't correct the noise problem. Any ideas?
Old Nov 4, 2004 | 04:57 PM
Takeo's Avatar
Default RE: 97 Discovery SE7 Winding sound
Hi !
Check oil level in gearbox, tansfer box and differentials, check wheel bearings also.
Regards,
Takeo.
Old Oct 22, 2007 | 01:35 PM
lee666's Avatar
3rd Gear
Hi if the above does not work has the diff lock ever been engaged for long periods on concrete ? this can cause diff wind up and can cause excessive diff noise
Old Oct 22, 2007 | 02:20 PM
Typical Rover drive train noise, not to worry, won't get any worse. If you want to try and get rid of part of the noise, change out your diffs and t/case using 85W/140 gear oil.
FlyingZebra34
Dec 22, 2012 04:15 PM
DiscoRover007
Sep 29, 2011 07:41 PM
Jdar
Jan 31, 2011 08:52 AM
mvjimenez
Jun 12, 2010 10:25 AM
rambo
Jan 18, 2009 05:52 PM
