Sponsored by: CARiD
Window not set?
Old Mar 5, 2010 | 10:22 AM
Chadillac's Avatar
4th Gear
Default Window not set?
I have a 99 range rover and when I open the sunroof I get a message on my dash saying the the sunroof is not set and it beeps when I open or close it and now my driver side front window is doing the samething? It will go up and down fine but not the automatic how do I fix this?
Old Mar 5, 2010 | 06:20 PM
Rovin4life's Avatar
put the window down then put it up and hold it till the message says window set for all four.
same with the sunroof, go back and the forward and the up and then down and it will set.
Old Mar 5, 2010 | 06:43 PM
Chadillac's Avatar
4th Gear
When I try that with my front window it just clicks when it's up all the way like it's trying to push it up more and with the sunroof do I hold it down untill I get the message? And the window only says not set when I put it up and the sunroof gives me the message all ways up down back and forward
Old Mar 7, 2010 | 06:11 AM
Rovin4life's Avatar
the window itself could be off track or damaged but the yes hold the sunroof up, down, back, forward and it should set.
bagocheetohs
Aug 11, 2015 06:13 PM
rtz62
Sights N Sounds
Apr 17, 2012 04:52 AM
nick731
Nov 16, 2010 12:25 PM
diego rover
Nov 7, 2007 04:22 PM
bobby82569
Mar 19, 2007 11:54 PM
