Sponsored by: CARiD
Wires ID -next to battery LR4
Old Jan 3, 2017 | 05:04 PM
Bogwhoppit's Avatar
Default Wires ID -next to battery LR4
Hello folks. Is there anyone out there who can ID these wires coming off the battery (vehicle is 2010 LR4)? One wire comes off +positive (brown w/blue trace) and the other two wires (green w/red trace and black) end in a plug. The reason I ask, is the two wires who terminate in a plug were trapped under the battery tray bolt head and stripped down to bare.
It looks like the previous owner put a new battery in and trapped those two wires that I since repaired, but it threw no codes or clouds of smoke. While I was under there I also noticed what looks like a missing cover over the two giant plugs (behind battery, next to firewall) which I assume connect to the computer, or is there actually no cover and it just looks like one is missing?
Any help appreciated.
Thanks again, newbie LR4 owner (but previous series IIa, 3, owner)
Old Jan 3, 2017 | 08:14 PM
LR Techniker's Avatar
Its for transportation when it comes over on the boat. From the factory, there is a Transit Relay on the positive battery cable. When the dealer removes it, they cap it off with a cap taped to the positive cable. This usually gets lost when the battery is replaced.
Also keep in mind that the battery monitor should be reset any time you replace a battery on a vehicle with a monitor (that is the device on the negative cable). Unfortunately that requires a Land Rover diagnostic tool.
Old Jan 3, 2017 | 08:35 PM
Bogwhoppit's Avatar
Great, thanks for the info Techniker. I was planning a trip to the dealer anyway, as I just installed the trailer harness and it doesn't show on the dash, so perhaps they can reset both then.
Old Jan 3, 2017 | 08:40 PM
They will charge for the trailer feature. They will have to hook up to the factory diagnostic terminal and configure the Car Configuration File (CCF) for trailer applications. The car will then think it left the factory with trailer option
Old Jan 3, 2017 | 08:56 PM
Bogwhoppit's Avatar
I should probably invest in one of those GAP tools as soon as the funds become available lol
Old Nov 19, 2022 | 02:31 PM
pchak's Avatar
7th Gear
Thank you! I came here looking exactly for this. Thought I pulled something out while replacing the battery.
cheers!
Old Dec 27, 2022 | 08:03 AM
adamolan's Avatar
emre
LR4
15
May 4, 2026 02:26 PM
Slippyghost
LR4
Sep 8, 2021 10:38 PM
hshamamian
LR4
Jan 20, 2020 03:30 PM
dfauver1
Aug 21, 2014 09:18 AM
JUHSTin
LR4
Mar 5, 2014 05:30 PM
