Sponsored by: CARiD
wiring a cb
Old Aug 24, 2008 | 07:30 PM
hazletbassist89's Avatar
Default wiring a cb
I have a 96 Disco SE7, just got a CB radio for it, but I can't figure out how to get power to it. What do most people do when wiring their CBs?
Old Sep 17, 2008 | 07:50 PM
kosho's Avatar
Default RE: wiring a cb
Haz, I have an 98 disco that I installed a CB in. I attached it to the back of the center console/glove box and wired it directly to the battery via a small drilled hole under the driverside fuse box, Attached to fuse and to the battery and then ground. The antenna cable I went under the carpet to the passenger side rear taillight asssembly access panel, there you will find an rubber gromett, pull it out and cut a hole in it and slide your cable through, then put back gromett. Antenna I have on the rear ladder. Hope this helps.
________
digital vaporizers
MiniManiac
May 21, 2007 08:55 AM
sheenalandi
Audio/Visual Electronics
Feb 9, 2007 04:23 PM
lovatt
May 3, 2005 07:58 PM
asmcmillin
Apr 4, 2005 02:04 PM
yorzak
Jan 25, 2005 01:25 PM
