Sponsored by: CARiD
Wobbly fan
Old Oct 1, 2023 | 11:47 AM
BraziliaNut's Avatar
Default Wobbly fan
Folks, weeks ago my Disco 2 started to chirp on the engine bay. It was a very subtly noise. Suddenly that because a quite loud "bang bang". Upon inspection, with the engine off, I couldn't find anything wrong. The belt and pulleys are in good condition, I then spin the fan with my hand, but couldn't notice any play at all, it looked fine. However, when I turned the engine on, I noticed the "bangs" were coming from a wobbly fan, which seems to be hitting its cover (and whatever else). I would appreciate if you guys could give me some tips of what might be wrong with it! Truck is a 2001 Disco 2 with 188k miles. Thank you in advance!
Old Oct 1, 2023 | 10:41 PM
Harvlr's Avatar
Hi. First, you should post your technical questions in the Disco 2 section of this forum.
Second, I would not drive it in this condition. There have been cases of fans coming apart and destroying the radiator and coolant hoses. I would suggest replacing the fan ASAP.
Old Oct 2, 2023 | 07:43 AM
Harvlr, yes, sorry I should have done that. And no, I haven't been driving it at all. Thank you.
Old Oct 8, 2023 | 02:25 AM
AlWorms's Avatar
It can be a failed waterpump bearing... or the fan viscous unit itself.
I just replaced the fan clutch on my Disco 1, because the fan wobbled due to the coupling being worn internally - the nut on the back was rigid on the waterpump, but the viscous coupling wobbled quite a lot.
landroverdude
Dec 4, 2019 06:31 AM
Zelatore
Dec 28, 2017 10:56 AM
RegT
Jun 23, 2010 08:32 PM
rrhyne
Jun 8, 2010 09:13 AM
A03
Nov 14, 2006 03:25 PM
