Sponsored by: CARiD
Land Rover Defender Starting Problem
Old Apr 27, 2014 | 04:23 AM
MallyRM's Avatar
Default Land Rover Defender Starting Problem
Hi, I'm new to the forum. I recently bought a 2004 Land Rover Defender 110 TD5 and I'm having problems starting it in the morning. It's done 120,000 miles.
If I turn on the ignition, wait for the glow plug light to go out and try to start it, it does not fire.
When I turn on the ignition I can hear what sounds like a pump running, coming from the rear of the vehicle, possibly the fuel pump? The pump runs for 30 seconds then stops. If I try to start the engine it does not fire. However, if I turn the ignition off and then on again and wait until the pump stops and do this several times then the engine fires and runs normally. The vehicle drives ok and will restart normally when warmed up.
I would be very grateful for any advice on what may be causing this problem.
Also, I am living in the Staines / Egham area in Surrey and would be grateful for any recommendations for Land Rover mechanics, either garages or individual enthusiasts who are willing to undertake repairs and servicing.
Regards to you all
Malcolm
Old Oct 9, 2023 | 01:10 PM
Jager55's Avatar
Default Same issue
Regards to you all
Malcolm
Hi,
Did you figure out what was causing the problem?
JMF20
Jun 2, 2023 08:25 AM
ahs1218
Defender
Apr 11, 2023 03:00 PM
Robworldwide
Defender
Jul 12, 2022 06:34 PM
boltsdefender
Defender
Feb 12, 2011 08:06 PM
ouranios
Mar 12, 2010 02:26 AM
