Sponsored by: CARiD
Won't start @ times, Crank Position Sensor?
Old Mar 2, 2008 | 04:50 PM
Woody Reems's Avatar
Default Won't start @ times, Crank Position Sensor?
When the engine is cold, I never have a string problem as of yet. But 3 times now when the engine is warmed up, I can turn is off for 5 min or so, then when I go to start it, is just turns over. All three times, I have to wait about 15 min or 20 min, and it would start right up. I did not smell and fuel, so I was thinking Crank Position Sensor. I can go a few days and never have the problem again, but I have noticed when it would not start the engine was already up to operating temp. Also I was going to also change out the fuel filter as well.
It's a 2000 Disco II with about 90,000 miles on it.
I look forward to everyones sugjesions.
Old Mar 2, 2008 | 05:12 PM
Default RE: Won't start @ times, Crank Position Sensor?
Any codes?
Crank sensors can fail and not throw a code so you may want to have a mechanic test it for signals.
Old Mar 2, 2008 | 06:28 PM
nope, no codes. I may just buy the sensor since the cost of a machanic would be about the same.
Old Mar 3, 2008 | 05:20 PM
Well, I just went to move my disco to the other side of my drive way and it's a nogo. Won't start now. What I have seen happen over the last 6 weeks started, while sitting at a red light the engine would die out of the blue. This has happened about 4 times, but would start right up. Now in the last 2 weeks, I have turned it off, then go to start it back up, and it would only just turn over, and that's about it. I would walk away for 15 min or so, then it would start right back up. Now it will never start.
Can't get it to a land rover shop, so I am open to what I shouold do? My thoughts would be to replace the MAF Senor, and the Crankshaft Position Sensor.
I read from this link:http://www.rangerovers.net/newrremedies.htm#cranksense
I don't know where to start, or if I'm starting in the right areas. Any help here would be great. I need it to pull my boat.....and it's almost spring.
Old Mar 6, 2008 | 01:01 PM
I just wanted to update this if anyone should search and find it. My problem was the Crank sensor. It was about 90 bucks to buy, and took about 2 hours to do it. I had trouble locating it, and removing it, but all my issues I stated above are gone. Hope this helps.
Old Mar 31, 2008 | 10:12 PM
CresFresh's Avatar
Im about to tackle this problem on my LR, where was the sensor located on the engine?
Old Apr 1, 2008 | 07:56 AM
By the way Woody, I hope you didn't buy a new MAF and hope you found you don't have a external fuel filter on a D2.
Old Jul 2, 2009 | 11:13 PM
psperez's Avatar
All,
I was having the same stopping and not starting problem. I had a engine that I had replaced and took the old crankshaft position sensor and the problem stopped ( for a few days) then started up again. I both a new one and replaced and so far I have not had the problem. After I replaced it with the used one and it when off, I started getting the following codes, P0134, P1590, P0335, P1884. P0335 was the code for crankshaft position sensor. Once I replaced it all codes were cleared. thanks for this posting as it helped me out quite a bit and thought I update for someone else having this issue.
Old Jul 13, 2009 | 07:39 PM
OlliesRover's Avatar
6th Gear
My 97 Disco 1 will not crank or make the starter turn at all. Any Ideas?
Old Jul 14, 2009 | 08:30 AM
Don't make us guess!!!!!!
What have you checked so far and be specific and don't get back to us till you have been all over your truck, starting with a bad battery and or dirty cables.
possibly owner
Sep 22, 2009 09:06 AM
oljohnboy
Mar 30, 2009 08:54 PM
wosmo
Aug 7, 2008 11:24 PM
DiscoOn22s
Apr 19, 2008 05:12 PM
lacruiser
Feb 28, 2008 07:24 AM
