Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Lose the cats and no fault codes
Old Dec 6, 2013 | 11:51 AM
toofaroffroad's Avatar
You need something called a 'spark plug non fouler" you'll need 4 of them, there are 2 in each pack. One of the 2 needs to be drilled out so the o2 sensor can fit. google this process, there are all kinds of videos and instruction.
Shouldn't be more than $5 for a pack of 2.
The threads are a direct fit with the O2 sensor and O2 bung.
Old Dec 6, 2013 | 07:04 PM
TOM R's Avatar
I bought nuts at Lowes to thread onto the sensors , stacked and welded 2 , then welded to the pipe, thread in sensor an voala, I have read online using spark plug non foulers drilled out but was unable to source the size I needed locally
Before you ask no I don,t recall the nut size, sorry
Old Dec 9, 2013 | 05:04 PM
Thought I should chime in on the last update. The Non-Foulers are universal. you don't need a LR specific one. All plugs have the same thread and all O2 sensors have the same thread. Just go buy some and they will work. Well...they will thread and screw in, I can't say with certantly that they will work.
Old Dec 10, 2013 | 06:01 AM
TOM R's Avatar
The stores around me sell at least 3 sizes none were correct size, if you could post the brand and p/n it would help them. : )
Old Dec 11, 2013 | 12:03 PM
Help Parts Universal 14mm Spark Plug Non Fouler Adapter S | eBay
Old Dec 12, 2013 | 12:52 PM
Charlie_V's Avatar
I bought.
Old Jan 20, 2014 | 10:27 PM
Charlie_V's Avatar
Originally Posted by Charlie_V
I bought.
Got these. The thread is too small.
Old Jan 21, 2014 | 05:27 PM
TOM R's Avatar
Think somewhere here other is a part # for spark plug non foulers, that work
I bought some nuts that thread on the o2 sensor , stacked and welded them together then welded to the bung, had pipes off at the time
Old Jan 22, 2014 | 08:46 PM
Charlie_V's Avatar
I like that idea. Found an old o2 sensor and am going to find some nuts.
Old May 30, 2014 | 02:11 PM
Dane!'s Avatar
bump. Charlie you ever find that thread size?
