2008 HSE auto transmission hunting/hard shifting when hot
Old Jan 29, 2024 | 04:11 PM
  #41
geotrash's Avatar
Originally Posted by guy
AND, was the procedure followed for the tightening of bolts. If I recall, in a clockwise motion from the mid point, alternating sides at each bolt(if that makes sense.)
Awaiting your response.
There is no tightening sequence given in the manual, so I used good engineering practice of starting with the bolt closest to the center on each side and working toward the corners. 14 Nm is the spec.
Not much more I can say until I can get it apart. If it's the pan, then this time I'll see if I can get a good bead of the correct sealant all the way around it instead of a rubber gasket, and we'll all learn something.
Old Jan 29, 2024 | 04:14 PM
  #42
geotrash's Avatar
Originally Posted by flybd5
Only thing I can say is that there is a good reason it came with RTV and not a gasket.
Yup. Ease of manufacture and an assumption that it's sealed for life and will never need servicing, to name two.
Old Jan 29, 2024 | 07:51 PM
  #43
geotrash's Avatar
Some good news: it appears that the leak was coming from the upper cooler line. I didn't tighten the screw holding it to the transmission case so it was quite loose. The pan gasket was dry apart from what traveled across the bottom from the leaking line. I gave the bolts that I could easily reach a turn with the torque wrench anyway and they all took a couple of pulls.
Old Mar 24, 2024 | 10:55 PM
  #44
geotrash's Avatar
Just an update here in the hope that it will help someone else. It turns out that the transmission pan gasket was indeed leaking, significantly. It was a rubber aftermarket gasket with an aftermarket pan, both made in China and purchased from a-premium.com. No quarrel with the seller - it was a cheap part and I knew I was taking a risk. But it’s finally fixed now and I wanted to wait a little while to be sure.
The root cause of the problem was that the aftermarket pan was a poor stamping, and when coupled with the unreinforced rubber gasket, the gasket itself was getting squished in such a way that it was seeping around the bolts.
So I cleaned up the original factory pan, removed all traces of the old sealer with a plastic razor, and bought a Duraprene reinforced gasket from Remco Transmission Parts on eBay. I pulled everything apart again, carefully installed the gasket and OEM pan, and torqued the bolts to spec. No more leaks.
So, for those of you who need to pull your transmission pan and are reading this thread later for guidance, you’re better off using the factory pan with a Duraprene gasket if you don’t want to use the factory sealant method. It’s a super tight working location with the transmission still in the car, so I personally think the sealant method will be problematic anyway. You’d likely smear sealant on the valve body just getting the pan into place.
This is the gasket I ended up using successfully:
https://www.ebay.com/itm/185605445018?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=i7xuqM40Tay&sssrc=4429486&ssuid=YmFdGJYXQe y&var=&widget_ver=artemis&media=COPY
Old Oct 25, 2024 | 03:30 PM
  #45
merlinj79's Avatar
Where did you get the OEM valve body from? I might be in need of one now...
Uriah Christian
Jan 18, 2024 11:30 AM
tnsubh
Jul 18, 2016 04:46 PM
min624
Oct 9, 2014 11:13 AM
mirepoixmatt
Dec 26, 2013 12:19 PM
mjane
LR2
Mar 27, 2012 08:05 PM
