2008 LR2 Anti Theft Module Location
Old Oct 23, 2021 | 05:07 PM
Cn17's Avatar
8th Gear
Default 2008 LR2 Anti Theft Module Location
I have an issue where my Passive Anti Theft will not be disabled on the vehicle preventing ignition. I can’t find any information on the Anti Theft Module passive the only module I can see apart of the overall Anti Theft passive system is the starter ignition control module.
Can someone drop a link to the Anti Theft Module or Passive anti theft module or advise if I will have to purchase and change the starter ignition control module instead?
Thank You
Old Oct 24, 2021 | 10:46 AM
flybd5's Avatar
Thank You
You already found it. It's the Start Control Module in the instrument panel. The FOB dock is part of it. If it is not working it has either unpaired itself from the FOB (requires the JLR SDD software to try to pair it again) or the module has failed. The battery in the FOB has nothing to do with that, that's only to operate the lock/unlock, lights and panic button.
Old Oct 26, 2021 | 07:38 AM
guy's Avatar
guy
hmmm… anti theft system engaged… is it YOUR vehicle? Are you using a proper fob or a knockoff?
cheers.
Tommyblack97
Mar 8, 2021 07:45 PM
Roverfanatic
Jul 31, 2018 02:04 PM
Mattwyckoff1
Dec 6, 2017 10:28 AM
tedjan
Aug 1, 2014 12:04 PM
Cirrus
Jan 21, 2007 01:36 AM
