2008 LR2 oil light at high speeds
Just changed my oil about a month ago. Used 8 quarts as recommended.
Almost every time I take a trip that involves an interstate for more than just a few mins (65-80 mph) the oil light will come on solid, not flashing.
I’ll add a quart and it will go away until the next time I have to hit those speeds again.
I live in rural Kentucky so I don’t use interstates everyday, just periodically so it’s not an everyday thing.
No oil puddles or stains in my driveway. No noticeable smoke from engine or exhaust.
Does it just burn a lot of oil at high speeds? Something doesn’t seem right if I have to keep adding a quart every time a take a trip.
Anybody have a direction I can look?
I wouldn’t say I’m sure, but it turned all the way until it completely stopped, not just tight, so I assume it seated properly.
I've changed the oil probably 15 times since I’ve owned it, and almost every time I would be wary of over tightening bc I was told the housing could break or something like that. The last time I must’ve just given it an extra quarter turn or something bc I felt it actually stop.
This problem predates the last oil change though so it’s been going on for awhile now.
I'd also check the vacuum pump area, that's a known oil leak point and with dust and dirt could stop it from actually leaking on the ground or the skid plate. Also, the fill amount s/b 7.7 liters but given your issue, a little extra might not be a bad idea for now.
EDIT, from memory, I believe @p_gill did replace a nipple/stopper(?) on the oil filter housing but I am pretty sure you would see a leak in and around that area.
I read his post and he never clearly indicated the time that actually passes before he would need a quart. What I can tell you is I would use a quart in about a month before I fixed the vacuum pump leak and I drove for about two hours+ daily and I check my oil level weekly. If he can't find a leak then he better check his exhaust as well as his coolant since the oil is definitely going somewhere.
Looking at the exhaust is also a good idea. But it would also indicate a major problem with the engine that should be causing the leak all the time, not just at high speeds.
Btw, racercard, what type and weight of oil are you using?
