2008 LR2 oil light at high speeds
Old Oct 2, 2021 | 01:18 PM
  #21
flybd5's Avatar
And you should start the engine before topping off to make sure the filter and housing fill with oil.
Old Oct 8, 2021 | 04:58 PM
  #22
p_gill's Avatar
LR2 Owners,
I originally changed my anti drain valve in 2016. Base on my post it was in April 2016.
https://landroverforums.com/forum/lr...ylinder-78803/
Its been 5 years and I decided to check it Today.
My LR2 had been sitting for about 24 hours and I checked the dipstick with the engine cold and the oil level was VERY HIGH.....WAY ABOVE THE MAX.
So I ran the engine for 30 seconds and shut it down and checked again and the Oil level was 3/4 of the way between Min and MAX (closer to MAX)
When I changed the oil I filled it to MAX so the 1/4 got burned up (Note: 1/4 in this case is 1/4 of a quart) its been about 3000 miles so its not too bad.
But my Anti Drain Valve has failed for the second time!!!!!!
I was anticipating 10 years not five and a half.
The failure isn't severe enough to set the Oil Pressure Light.............I don't know what the light looks like I've never seen it.
I will check the Volvo because I replaced that Valve slightly less than 3 years ago.
Thanks
Paul
Old Oct 8, 2021 | 07:25 PM
  #23
p_gill's Avatar
Update
I checked the Volvo 3.2 (same engine as the LR2)
And after sitting for a few days the oil had drained back into the pan.
Apparently the Anti Drain Valve isn't that good. (the Valve on the Volvo isn't very old)
The take away................follow #FLYBD5's advice and start the engine if you really want to know if the level is correct.
Take care
Paul
Old Oct 11, 2021 | 05:07 PM
  #24
p_gill's Avatar
LR2 Owners,
One last update.
If you check the Engine oil level at the Gas Station (Which is what I was taught to do)
Then the Anti drain Valve works as expected and the Oil level measurement is correct.
Note my S80 has redesigned piston rings and those rings are prone to burning oil.
And my S80 does burn oil faster than my LR2.
If I change the oil every 6 months or 5,000 miles
Then the 2008 LR2 will be below the max by 0.3 quarts (out of 8 quarts about 4%)
And the 2010 S80 will be below the max by 0.6 quarts (out of 8 quarts about 8%)
I do know that the previous owner of my S80 used crappy oil.
Because the Brake Vacuum pump O-rings were leaking severely.
For my LR2 where I only used a good synthetic oil since new the Brake Vacuum pump O-rings are original.
Take care
Paul
Old Oct 12, 2021 | 10:00 AM
  #25
merlinj79's Avatar
When I run the car to fill the filter canister after an oil change, it takes close to ten seconds for the oil light to go out.
Normally it takes 2-3 seconds.
So that might be an easy indication, just note how long the oil light stays on anytime the car has been sitting for a while.
Old Oct 12, 2021 | 10:02 AM
  #26
flybd5's Avatar
The oil is not supposed to drain out of the canister when the car is not running. The valve is spring loaded and should not open while the filter is installed.
Old Oct 13, 2021 | 03:35 PM
  #27
p_gill's Avatar
My LR2 oil light turns off very quickly even with the oil filter housing emptied back into the sump
If you watch the video you will see that the light is on for about 3 seconds
But if you watch the Tach you will see that the light turns off about 1 second after the tach moves
IMG_6962.MOV
At least I got to see my oil light
Thanks
Paul
PS I checked the dipstick and the oil had drained into the sump
File Type: mov
Old Oct 14, 2021 | 09:36 AM
  #28
merlinj79's Avatar
Maybe it takes longer to fill a new dry filter.
Old Oct 14, 2021 | 09:56 AM
  #29
flybd5's Avatar
That's different. Yes, it does.
Nitrolr2
LR2
Oct 28, 2021 10:56 AM
LR2driver
LR2
May 14, 2021 04:18 PM
zoltz
LR2
16
Jun 9, 2020 06:43 PM
Inkstaind
LR2
May 29, 2020 10:51 AM
LR2driver
LR2
Nov 6, 2013 08:21 PM
