2008 LR2 Rear Wheel Bearing Replacement
Hi. I would be interested in knowing also. 2008 LR2 with 104,000 getting loud right side. Since I'm in there, do I do both sides? Just started to look into the feasibility of me doing the work or the shop. Thanks! If I find any answers outside of here I will share. Getting back on our feet financially; had disabling health problems and job down-sizing...so really do not want to pay for shop overhead if do not have to.
what if dif service LBT00342
BritishautoworksSD - Pinion Bearing Spacer: Technical Service Bulletins
Drivetrain - Rear Differential Service Repair Info. No: LTB00342. What if the symptom/sound that I'm hearing, thinking is the bad wheel bearing, is actually the more popular failure of the pinion bearing as noted above. Could a somewhat intelligent, experienced mechanic-me, do this job? Complaints I have read about are noises from the right axle side, whereas my job sounds like the left side-idk until it is opened up. Thank you.
Not sure if you still need help but see my post here
Freel2.com - View topic - Rear Wheel Bearing Lesssons
2008 lr2
I just got 4 new tires and replace my bearings and service the differential, as soon as i had the differential serviced.
The transmission fault traccion reduced
dsc off
and terrain responce system faulty light came on,
y replaced the battery and the alternator and nothing the same message apears each time y start the car
dsc off
