2010 LR2 HSE Check Engine?
Old 04-27-2019 | 04:12 PM
Jvh75's Avatar
4wd High
Default 2010 LR2 HSE Check Engine?
2010 LR2 HSE with Check Engine. Codes from scanner are P0069 and P0108. I have the associated descriptions. Car is running fine. What component is causing this? What is the fix? Thanks.
Old 04-27-2019 | 04:20 PM
DakotaTravler's Avatar
Seems like a bad MAP sensor.
Old 04-27-2019 | 04:56 PM
Jvh75's Avatar
4wd High
Thanks. It looks straightforward to install. Is it more difficult than it seems i.e. should it go to the Land Rover dealer for repair?
Old 04-27-2019 | 07:20 PM
Its probably easy but I am not certain as I don't have an LR2. On an LR3 is not an easy task because of its location, on the far back of the intake.
Jvh75 (04-27-2019)
Old 05-16-2019 | 06:04 AM
Jvh75's Avatar
4wd High
It was the MAP sensor. Indy Land Rover replaced the bad sensor and wires. Cost about $400. Check engine light and white smoke from tailpipe gone.
champion
LR2
08-18-2017 12:46 PM
Pbpuckett
07-13-2015 07:03 PM
drzjoint
LR2
05-21-2009 08:04 AM
torres
LR2
12-25-2007 07:29 AM
05LandRover
Freelander
12-18-2006 05:17 AM
