2010 LR2 HSE Check Engine?
Old Apr 27, 2019 | 03:12 PM
Jvh75's Avatar
4wd High
Default 2010 LR2 HSE Check Engine?
2010 LR2 HSE with Check Engine. Codes from scanner are P0069 and P0108. I have the associated descriptions. Car is running fine. What component is causing this? What is the fix? Thanks.
Old Apr 27, 2019 | 03:20 PM
DakotaTravler's Avatar
Seems like a bad MAP sensor.
Old Apr 27, 2019 | 03:56 PM
Jvh75's Avatar
4wd High
Thanks. It looks straightforward to install. Is it more difficult than it seems i.e. should it go to the Land Rover dealer for repair?
Old Apr 27, 2019 | 06:20 PM
Its probably easy but I am not certain as I don't have an LR2. On an LR3 is not an easy task because of its location, on the far back of the intake.
Old May 16, 2019 | 05:04 AM
Jvh75's Avatar
4wd High
It was the MAP sensor. Indy Land Rover replaced the bad sensor and wires. Cost about $400. Check engine light and white smoke from tailpipe gone.
champion
LR2
Aug 18, 2017 11:46 AM
Pbpuckett
Jul 13, 2015 06:03 PM
drzjoint
LR2
May 21, 2009 07:04 AM
torres
LR2
Dec 25, 2007 06:29 AM
05LandRover
Freelander
Dec 18, 2006 04:17 AM
