2010 LR2 whinning noise
Old Apr 18, 2019 | 06:14 PM
aaron1578's Avatar
Default 2010 LR2 whinning noise
when idling there is a loud whining noise, thought it was idler pulley, change both of them, and water pump. Would alternator make that sound?
Old Oct 13, 2019 | 11:15 PM
bornhandy's Avatar
4th Gear
Old post, I know, but did you check your PCV valve? If you pull the dipstick, and it stops - you likely have a bad pcv valve.
Old Oct 29, 2019 | 09:07 PM
ninjaff21's Avatar
Yes it’s more than likely the read unit that powers the alternator and other accessories. Go on the Volvo forms and look into READ unit failures on 3.2s and you will see. Common on pre 2011 3.2s
clovis996
LR2
Jul 21, 2021 11:55 AM
schuerleinb
LR2
Mar 27, 2017 06:24 PM
raygon
LR2
May 23, 2014 11:56 PM
dbartlett
Jul 29, 2012 10:15 AM
jquatrella
Feb 29, 2008 11:12 AM
