2014 LR2 2.0L Petrol L359 4 cylinder
Old Oct 19, 2022 | 11:41 AM
khanash's Avatar
Default 2014 LR2 2.0L Petrol L359 4 cylinder
Hi,
Any advise on changing the transmission oil on my 2014 LR2. which has approximately 86 K miles. Recently noticed that it slips gears while driving.
Planing to do a transmission fluid change DIY and need help with which fluid to buy and where to buy the drain plug and drain plug gasket.
Thanks
Old Oct 19, 2022 | 03:10 PM
merlinj79's Avatar
You will need one of these two specs for the fluid:
Early Tranny: AISIN ATF-0T4 (JWS 3309 / Toyota T-IV)
Later Tranny: JWS 3324 (Toyota WS)
Not sure when the tranny changed, you'll need to google that. I'd guess you need the later spec with a 2014.
Discussion here...
https://www.freel2.com/forum/topic32297.html
For the plug gaskets and oring, just need to google around. I had to order from several places to get all the parts in a timely manner. You could try your local JLR dealer.
This thread has a discussion for fluid changes on the older gearbox. I'm not sure how similar the new one is, but it's probably not as simple as a drain and fill. Probably need multiple drain/fill cycles, and will need to check fluid temp with an advanced scantool, or an IR sensor to set the level correctly at the end...
https://www.freel2.com/forum/topic28619.html
fasterdamitt
LR2
May 9, 2024 11:09 PM
Justin Ruiz
LR2
Jul 16, 2021 07:03 AM
NENYMA
LR2
Jun 3, 2014 06:14 PM
tress
LR2
Apr 7, 2010 05:45 PM
05LandRover
Freelander
Dec 18, 2006 04:17 AM
