2014 LR2 Help Needed!!!!
I have a 2014 LR2 with a specific problem that I can't get my brain around. At about 1/3 of a tank of gas the car dies as if it is out of gas. I've been filling it up at 1/2 a tank for the last year but that's getting old. I have been told that the fuel tank has two sides (left and right) where the fuel injection pump only sucks from one side and there is a transfer pump that moves fuel from the other side of the tank to the side where the fuel injection pump sucks. That makes sense in the way the car is behaving.
I can't find any literature or anything online to prove that it has a transfer pump, where that pump may be, and how to replace it.
HELP :-)
HELP :-)
There are definitely two sides on he 2008-2012, basically there's a saddle in middle of the tank for the rear differential. There are separate sensors and systems in both sides, and I'm pretty sure you need to drop the differential and fuel tank to access those. The access ports are on top of the tank. I'd assume the 2014 is very similar, they changed the engine but I think a lot of the rest is the same.
If you do drop it I'd replace all the seals, they fail over time and it's a lot of labor to drop the tank again for a seal.
Here's a link to some of the manuals, the 2012 might be the same.
https://www.freel2.com/forum/topic10621.html
