ABS Location and Voltage
Old Oct 22, 2021 | 08:11 PM
flyer08's Avatar
Default ABS Location and Voltage
Have a 2011 LR2 with the three amigo dash light showing. Using the GAP II Tool have code
C0020-1C {2B) ABS Pump motor control
General electrical failure- circuit voltage out of range
See pic
Anybody knows what this is and possible fix?
Next, where is the ABS module
Fyi - front power windows stopped functioning at different times and after ABS, Brake, and HDC lights came on. Don't think related but my LR3 would not auto shift due to a burned out tail light. You can hear a click in the door when window switch is pushed.
Last, should the GAP II give a code on the power windows not working?
Old Oct 22, 2021 | 08:12 PM
flyer08's Avatar
Old Oct 22, 2021 | 08:26 PM
flyer08's Avatar
Car runs and drives fine. ABS seems to work, cant lock up brakes stopping. LR2 stops very well
Old Oct 23, 2021 | 11:32 AM
flybd5's Avatar
Old Oct 23, 2021 | 11:45 AM
flyer08's Avatar
Thanks flydb5
I did locate the module and found a post you made of same a while back.... Very helpful and appreciated.
Let you know what I find
chockster
Feb 20, 2017 03:41 AM
Michaelnizami
Jun 28, 2014 12:18 PM
myquealer
Feb 11, 2012 03:56 PM
Aj6543
Sep 28, 2009 03:15 PM
