Air issues
Old Nov 5, 2020 | 03:14 PM
manny331's Avatar
3rd Gear
Default Air issues
Regardless of the settings the air only blows out of the lower vents and warm once the car is warm. Is this the HVAC door actuator or temp sensor issue? Any help would be much appreciated.
Old Nov 5, 2020 | 05:05 PM
ThorInc's Avatar
Sounds like the HVAC door actuator; have you tried the auto setting?
flybd5's Avatar
Have you read any error codes from the computer?
Old Nov 5, 2020 | 05:36 PM
manny331's Avatar
3rd Gear
Yes, I tried in auto and there were no error codes when I scanned it.I'm thinking the door actuator is stuck in the lower heat position.
Old Nov 6, 2020 | 04:22 AM
ThorInc's Avatar
You will need a reader that can scan the HVAC system specifically as well as the BCM, etc. Try locating the fuse(s) that controls the HVAC system and remove and reinstall as a possible reset of the system. You can also try a "hard reset" of the entire vehicle to see if that helps; Google is your best friend as to how.
Old Nov 6, 2020 | 08:15 AM
manny331's Avatar
3rd Gear
Thank you all for your input!
acg
Aug 27, 2020 05:07 PM
NIC1221
Jun 13, 2020 07:16 PM
Miwo
May 4, 2011 08:40 AM
slexum
Jul 23, 2009 02:43 PM
mom2bekah
Nov 26, 2007 04:53 PM
