Anyone familiar with this error code?
Old Feb 25, 2026 | 10:33 AM
CharlesMann's Avatar
Default Anyone familiar with this error code?
Old Feb 25, 2026 | 11:15 AM
ThorInc's Avatar
Per AI,
"I OverviewIn JLR Symptom Driven Diagnostics (SDD), error code
A19 is a generic communication or application error indicating that the software has failed to properly initiate or communicate with the vehicle. It is often described as a "catch-all" error, meaning the software does not know exactly what is wrong, but the routine has failed.
  • Battery Voltage: SDD terminates routines if the battery voltage drops below 12.8 Volts. Ensure a Jaguar Land Rover-approved battery power supply is connected to the vehicle during diagnostics.
  • VCI/Cable Connection: Check the connection of your Mongoose Pro or alternative VCI cable. Try unplugging and re-plugging the USB cable, or restarting the laptop.
  • Driver Issues: Ensure the VCI drivers were loaded onto the laptop before plugging in the cable.
  • Software Bug/Version: SDD is no longer actively maintained by JLR, and some versions (especially cracked or outdated ones) may trigger this error.
  • Alternative Solution: If the issue persists, consider using different diagnostic equipment, such as an IID BT from GAP Diagnostics.
If you are using a virtual machine, ensure it has proper access to the USB port "
Are you using a supply charger with a constant 13 volts and at least 20-25 constant amps?
The supply charger is a must, and if the voltage drops below 13 volts, the program will error out when flashing.
I won't post this on the other site since you can read this here..
ReignRock
Oct 11, 2023 05:08 PM
Dclick
Sep 3, 2023 03:24 PM
merebel
Jun 20, 2020 05:35 PM
film842
May 2, 2015 10:21 AM
vithooantony
Defender
Nov 25, 2014 11:23 PM
