Brake and Tail light issue
Old Mar 14, 2022 | 07:02 PM
Frani's Avatar
4th Gear
Default Brake and Tail light issue
Passenger side brake light and tail light are out but blinker works. Have replaced bulbs with Land Rover bulbs, replaced wiring harness and checked all fuses. Checked the harness with ohm meter and there is power coming to the brake and tail light. Any suggestions would be appreciated!
Old Mar 14, 2022 | 07:03 PM
Frani's Avatar
4th Gear
This is a 2010 LR2
Old Mar 14, 2022 | 07:56 PM
ThorInc's Avatar
I suck at electrical but have you tried the same replacement bulbs on the DS?
See post 3 of this thread and onward:
https://www.freel2.com/forum/topic33...et+tail+lights
It references a CJB reset and how to execute it.
Old Mar 15, 2022 | 07:33 AM
Frani's Avatar
4th Gear
I also suck at electrical, just not my thing, anything past common sense is above my thought process! Thank you for the information, I will try the reset.
Old Mar 15, 2022 | 09:58 AM
flybd5's Avatar
The contacts inside the sockets likely need cleaning. Lightly rub them with an eraser or a piece of sandpaper. That will likely get them working again. It is not uncommon for moisture to get in there and cause corrosion.
Old Mar 15, 2022 | 10:45 AM
Walter_F's Avatar
^^ This ^^
Had the same issue with my driver side's tail/brake bulb. A tiny piece of sandpaper wrapped around a screwdriver tip let me get in there and clean it up. You might also consider a dab of electrical contact grease on there to help keep moisture and corrosion from returning. Make sure the lights are OFF before you go sticking anything in the socket.
Old Mar 15, 2022 | 11:23 AM
flybd5's Avatar
Yes, dieletric grease is also a great idea.
Old Mar 16, 2022 | 09:06 AM
merlinj79's Avatar
I use it a lot. But it's only suitable where there's a firm physical connection, which is typical of modern connectors. It can be counter-productive on some vintage car connectors.
The grease itself does not improve conductivity, once you establish good conductivity by cleaning, it helps preserve that by keeping moisture out to prevent corrosion.
redrover75
Dec 6, 2018 02:38 PM
huggi
Oct 22, 2018 06:07 PM
TRIARII
Jul 7, 2018 06:33 AM
disco 03
Sep 3, 2016 07:42 PM
Kalel
Mar 29, 2012 08:31 PM
