A/C compressor malfunction causing check engine light?
Old May 11, 2024 | 03:09 PM
NLjamjam2024's Avatar
Default A/C compressor malfunction causing check engine light?
Have a 2011 Freelander 2. A few weeks ago A/C starting humming on full blast. We still used it on Low and it blew cold. Now the check engine light came on with a rubber burning smell. Could it have finally went and now caused check engine light to turn on?
Old May 11, 2024 | 04:19 PM
Hugh166's Avatar
Have you scanned it for codes? Once we see the code we will be able to determine if it is related to the A/C or not
Old May 11, 2024 | 06:14 PM
do recommend a tool to scan for codes? I am in Jamaica so would have to send one down
Old May 11, 2024 | 09:23 PM
flybd5's Avatar
Autel AP200. Activate it with the Land Rover diagnostics. You get one lifetime activation for free.
Old Jun 2, 2024 | 06:33 PM
IT ended up being the ignition coils, so replaced those and the spark plugs.
Old Jun 3, 2024 | 12:11 PM
merlinj79's Avatar
Burning rubber smell and AC problems hints at an accessory belt issue. Check the condition of the belt, since it drives the water pump if it fails you'll quickly overheat the engine.
The CEL was most likely caused by the coils/plugs, not the AC. The CEL is mainly emissions related equipment, or anything which would make the engine run badly and pollute (misfires, bad timing, etc). CEL will typically not come on for accessory issues like AC, PS, etc.
NLjamjam2024
Freelander
May 11, 2024 03:02 PM
Imi39
May 9, 2024 05:47 AM
shmassey1@roadrunner.com
Oct 30, 2009 07:44 PM
greenlander
Oct 29, 2008 02:13 PM
NCdiscoII
Nov 16, 2006 12:12 PM
