code P2118
Old May 25, 2021 | 09:37 PM
Bbg's Avatar
Bbg
Default code P2118
Hi Fellas,
i had a code today P2118 i m getting of tired this car before go to the mechanic id like to ask you guys do you have any advice.
thanks
Old May 25, 2021 | 10:16 PM
ThorInc's Avatar
Did you google the code?
https://www.google.com/search?q=P2118
Old May 25, 2021 | 10:18 PM
Bbg's Avatar
Bbg
Yes i already did , i have an electric problem also i think it s related with that , thanks anyway
Old May 26, 2021 | 10:30 AM
flybd5's Avatar
It would help to know what year your car is, and confirm it is an LR2.
Old May 26, 2021 | 10:40 AM
Bbg's Avatar
Bbg
2012 land rover lr2 hse,
i just wanted to know,do I have to do something before go to mechanic, I don't like to touch people who don't know their job
thanks for time
Old May 26, 2021 | 10:51 AM
flybd5's Avatar
Your throttle body may need replacement. If you don't like your mechanic you should be looking for a better one.
These cars do not have mechanical throttles. When you press on the accelerator a potentiometer sends a signal which is translated to movement of a motor in the throttle body. The error code is telling you the computers thinks the motor is failing, or somewhere the wiring is shorted. The service manual says to check the motor on the throttle body and its circuits, and install a new throttle body assembly if necessary. To do so you need to get underneath the truck, remove the undershield, then remove the air intake from the throttle body and remove four bolts to release and remove it. Reverse to install. Not exactly a complicated job, but it helps if you have a lift.
Old May 26, 2021 | 10:56 AM
Bbg's Avatar
Bbg
thanks a lot i will do it , i ve changed an oil recently after oil changed it happened , thanks again
Old May 26, 2021 | 10:58 AM
flybd5's Avatar
Then check the connector and wiring first, make sure the connector is properly seated, and make sure you didn't pinch any wiring in the process.
Old May 26, 2021 | 10:59 AM
Bbg's Avatar
Bbg
ok i will do , thanks again
film842
May 2, 2015 10:21 AM
drowssap
Feb 10, 2015 09:38 PM
vithooantony
Defender
Nov 25, 2014 11:23 PM
gavone1976
Nov 19, 2012 02:00 PM
DiscoDos
Mar 4, 2011 06:54 PM
