Coolant lead in 2014 LR2 - can I use stop leak fluid?
Old Jan 23, 2019 | 01:15 PM
LR2inColorado's Avatar
Default Coolant lead in 2014 LR2 - can I use stop leak fluid?
During a 40k check-up at the land rover dealer they told me there is coolant leaking (they did not specify where) and that it would cost US$1700 to repair. They said I cannot use any of the stop lead products because the radiator is plastic/aluminum. Is this true?
Old Jan 23, 2019 | 01:49 PM
DavC's Avatar
First step. They need to tell you where it is leaking. Go back, get on the phone, get the report from the tech, talk to the tech.
Skip the service advisor at that point.
Old May 28, 2019 | 10:13 PM
guy's Avatar
guy
I get pricing ideas from here: https://www.rockauto.com/en/catalog/...,radiator,2172
Old Jun 5, 2019 | 09:57 AM
razorgaze's Avatar
have you isolated where coolant is pooling, i.e., below water pump, radiator, more to the passenger side? I have 215K miles on mine and had a leak as well. Well, my thermostat went bad and so while replacing it, on the good advice of another forum member, paul_g, i also replaced the hoses. Turns out, the small hose going to the heat exchanger (next to the thermostat) had finally succumbed to age and cracked where it connects to the engine and was the cause of my leak. Again, paul_g to the rescue, advised to replace the o-ring which usually goes bad but in my case, it was the hose itself. To my surprise, my thermostat repair simultaneously repaired my coolant leak.
It's not an easy job, but it's not a hard one either.
m
ZMonet
Jun 24, 2016 04:00 PM
Jflo63
Mar 30, 2015 08:32 PM
ROVERRACER
Jan 9, 2015 08:17 AM
Vantablian
Jul 8, 2013 10:53 AM
tom_meeks@yahoo.com
Aug 14, 2008 05:40 PM
