Coolant pressure tester for 3.2 I6
Old Dec 29, 2022 | 01:50 PM
  #31
Hamza89's Avatar
Originally Posted by p_gill
https://landroverforums.com/forum/lr...on-plz-114192/
Personally I upgraded to G13 (Audi or VW will sell it to you)
If you want a brand name
Pentosin PENTOFROST E
The E is the G13 spec
Take care
Paul
​​​​​​​Thx Paul
Old Dec 29, 2022 | 09:32 PM
  #32
flybd5's Avatar
Originally Posted by Hamza89
I am fishing for a coolant leak , i got a universal coolant pressure test kit from a friend but non of the expansion tank caps would fit , anyone has a link for a pressure test kit that fits our expansion tank ?
I use PEAK OET Antifreeze and Coolant European Vehicles Pink Concentrate. I dilute it 50% with distilled water as per the instructions from my home water distiller that I also use for medical purposes.
Old Dec 29, 2022 | 09:48 PM
  #33
Hamza89's Avatar
Thanks man
Old Jan 21, 2023 | 03:13 PM
  #34
Hamza89's Avatar
So this is the access to the radiator, fan , and thermostat.
Dont you worry the cylinder head is still attached 😆😆
Old Jan 21, 2023 | 03:14 PM
  #35
flybd5's Avatar
Old Apr 10, 2023 | 06:33 PM
  #36
Hamza89's Avatar
Update : the car was fixed long ago im sorry I forgot to update , so the job was horrible, i replaced one of the fans , the radiator, the thermostat, the upper and lower hoses , the coolant return hose , and finally i discovered that the coolant reservoir cap installed by the stupid previous owner is not the correct cap , which caused the car to overheat and cost almost a 1000 $ to fix , all because of a 10 $ cap .
the access was horrible as you can see from the previous picture , other than that it was a standard job .
Old Apr 10, 2023 | 06:35 PM
  #37
flybd5's Avatar
Wait what? You replaced all those parts when a new cap would have fixed the problem? I would have shot something.
Old Apr 10, 2023 | 06:42 PM
  #38
Hamza89's Avatar
No man of course not , this wrong cap caused the car to over heat several times , not only under my watch i think it over heated with the previous owner also so he sold it , this continues overheating caused one of the fans bearing to fail coz it was working all the time , and it caused the radiator the thermostat and all the other hoses i mentioned to leak ( confirmed by pressure testing ) , so i had to replace all that anyway, but i was lucky to notice the cap issue after finishing the work otherwise the overheat would have occurred again and all the new parts would be destroyed .
Old Apr 10, 2023 | 08:08 PM
  #39
flybd5's Avatar
Ahhh, i get it now. Sorry, i was at the VA today for a bad cold and they gave me drugs that f**k up my reading comprehension. 🤣🤣🤣
Old Apr 10, 2023 | 08:11 PM
  #40
Hamza89's Avatar
no worries man ger well soon 😆😆
And keep us posted regarding your car , good luck 👍
