Dead dash light
Old May 23, 2021 | 08:14 PM
Bbg's Avatar
Bbg
Default Dead dash light
Hi fellas ,
i have an electric problem on my lr2 dash electric went out but other all things working properly,
i read same thing but i couldnt see any solution
is there any one live same problem like me
thanks
edit : I opened fuse box under the hood and pushed all of them with my hand , then started to work again
but for sure it will give me an error again I know it s temporary
Old May 29, 2021 | 07:03 AM
guy's Avatar
guy
I can't tell from your post specifically what vehicle and year are we talking about here. Add to that, when was the last time the fuses were pushed back into place? And does the vehicle frequent jarring/shaking/aggressive drives?
Temperature extremes, ...
Old May 29, 2021 | 07:11 AM
Bbg's Avatar
Bbg
Land rover 2012 lr2 hse
I pushed back fuses last begining of this week
After that i had p2118 code on dash i tried to fox it but i did not, went to mechanic delete code said drive few days ,now it s ok but i m sure that there is electrical problem i ll go to dealer i think
thanks
Old May 29, 2021 | 08:17 AM
guy's Avatar
guy
With these electronics sensitive vehicles,
1. do not discount the importance of a good battery (as in really good and completely charged)
2. I perform a hard reset every 2 years. (disconnect battery, touch + and - leads together, reconnect battery)
With the SDD software, LR specific modules will show important status codes. Generic ODBII readers will not show these codes.
Modules will degrade.
Old May 29, 2021 | 10:24 AM
Bbg's Avatar
Bbg
There is a
Since 2017 there is a 700 amps battery on it , but when i checked from autozone at least 800 or 850 amps battery supposed to be on it i went mechanic and checked life time of battery he said all good , all good means a alternator , starter and battery , I can not solve this problem by my self , i need to go to mechanic . And not all mechanic uses sdd software they just use odb2 reader and if they see Any code on screen change the part ThAnks your advices though
Old May 29, 2021 | 11:33 AM
flybd5's Avatar
Where are you located? You need to go to a reputable Land Rover mechanic, not some random wrench turner with a cheap scanner.
Old May 29, 2021 | 11:45 AM
Bbg's Avatar
Bbg
Live in west new york , nj
There are 2 special land rover service close by to me
roverspecialist.com /clifton nj
britishautoworks.org/ bronx ny
but i d like to go to land rover dealer first make an all electric short circuit , wire , battery , fuses diagnoses, get a report , then if car needs anything go to a my own mechanic so i can save some money, dealer charge 543$ for battery change at least .
Old May 29, 2021 | 11:46 AM
flybd5's Avatar
There's no point in posting anything else here until you have it properly diagnosed. You don't need to go to a dealer for that.
ljdiscovery
Dec 31, 2019 09:50 PM
GBR.R
Feb 19, 2017 05:27 PM
earlyrover
Jun 17, 2016 09:05 AM
umwolverine
LR2
Nov 28, 2014 05:30 PM
lrjon
Feb 7, 2013 10:16 AM
