Today while driving my 2009 LR2 in the highway the overheating light and alarm came on so i stopped the car immediately and i took a look at the engine and i am not sure if what i saw is correct!!
it seems i have a mix of oil and coolant all over my engine, but i didn't have any issues with the car and it didn't stop functioning or anything.
any ideas on what might have caused this ?? you can take a look at the pictures below.
I would guess it does look that way considering it sharted on the motor.
It sounds like you are getting oil into the coolant, one way that can happen is head gaskets, another is if it has a oil cooler built into the radiator. Unfortunately I don't know enough about the LR2 to help to much.
The failure can be caused the heat exchanger for the transmission (as shown above)
But based on the failure that others are seeing it is more likely the heat exchanger for the engine oil and coolant
The picture is for a slightly different 3.2 but it is similar to the LR2 version
The part that fails is the rectangular part with the stacked aluminum plates, the oil and the coolant pass thru this to transfer heat from the oil to the coolant.
For reference the part next to the stacked plates in the oil filter housing.
