Freespender2 2008
Old Jan 3, 2024 | 09:54 PM
Ddogmatic's Avatar
Default Freespender2 2008
Hey all. Happy anew Year to you! I am having some issues with my Freelander2/LR2 that I suspect are related to transmission and /or motor mounts. Can anyone link me to any step by step tutorials with video(pics are fine too) for checking,changing,filling tranny fluid, and also for changing motor mounts? You’re all top notch people! Thanks!
Old Jan 4, 2024 | 01:12 PM
flybd5's Avatar
Try the Service Manual first, it can be downloaded for free, just search for service manual on this forum.
Keep in mind that on the LR2 there are engine mounts and there are engine mount INSULATORS. The latter are much more likely to be your problem, and they are not difficult to change if you have the right tools. I just did mine. You can buy a full set of three insulator mounts on eBay for $88 and change.
Old Jan 4, 2024 | 05:55 PM
ThorInc's Avatar
The manual will also tell you how to change the transmission fluid. Technically the level must be set at 50-60 degrees fluid temp and you can find videos on Youtube on said Aisin transmission with the si6 engine in the Volvo models. I tried a variety of compatible fluids including Amsoil synthetics and ultimately found that the transmission responded the absolute best to the Aisin ORIGINAL (non synthetic), I believe the J3309? Whatever it is, it's the exact fluid it came with from the factory and not the preceding Aisin newer fluid.
If you choose to drain and fill, just put back in what you took out and maybe do that 5-6 times over a few weeks. At the time I got a case from rockauto, they had the best price.
It can't hurt to buy a new fill plug (which sits under the air box) as well as it seems to torque the heck out of itself over time likely from the hot and cold cycles. You can weld a nut to the original as an improvement .
anc001
LR2
Oct 11, 2023 03:55 PM
ofir
LR2
Jul 24, 2023 06:56 PM
Ddogmatic
LR2
Nov 3, 2022 04:27 PM
Sing
LR2
Mar 21, 2019 07:26 PM
Kflex
Jan 19, 2016 08:14 PM
