Fuel smell in cabin
Old Dec 13, 2022 | 10:12 PM
DZD's Avatar
DZD
Default Fuel smell in cabin
Recently, I've noticed that my 2013 LR2 HSE (2.0 turbo 4) smells like fuel after I start it up when the engine is warm. There are no codes and it drives excellent. Have any of you encountered this? Thanks.
Old Dec 14, 2022 | 06:52 AM
pbraj's Avatar
I've had the same issue once or twice, but it is random and have never been able to pinpoint any issue. Never got it again after the last time.
Old Dec 14, 2022 | 11:02 AM
merlinj79's Avatar
Might be the evap system, which is not a big deal. But I'd inspect it carefully to make sure you don't have an actual small fuel leak... that would not set a code, but would start a fire which would destroy the car.
Old Dec 14, 2022 | 04:23 PM
flybd5's Avatar
The evap system components have a tendency to break down. The most common one is the purge valve near the intake manifold. That costs about $25 + labor and is a relatively easy DIY job if you're up to it. I have a spare purge valve if you need it, but it is for my 2008. Not sure if the 2013 is the same valve.
Harder to fix and more expensive is the canister and pump, located over the rear left hand side wheel well.
A strong sign is that when you open the fuel cap you can hear the pressure equalizing.
Old Dec 17, 2022 | 06:48 PM
DZD's Avatar
DZD
Thanks for all the replies. I'll pass on the info and have it checked out and keep you posted.
redrover75
Aug 28, 2022 07:03 PM
ourx15
LR2
Jul 26, 2022 11:08 AM
gregbates
LR2
May 24, 2022 04:16 PM
Spud64
LR2
Sep 18, 2018 02:23 PM
transporter
LR2
Jun 4, 2014 10:15 AM
