Haldex unit
Old Jul 28, 2017 | 03:00 PM
MARANT23's Avatar
8th Gear
Default Haldex unit
y anplug the Haldex unit and all the rubbing sound at the differential when turning the steering wheel are gone,
however that turn on the Transmission fault traccion reduced and the terrain response system faulty sings,
cuestion will this affect the function of the car
Old Aug 2, 2017 | 09:56 AM
SoCalLR2's Avatar
There is a somewhat fragile wire connection from the Haldex unit that may have been damaged or disconnected that will cause that error.
Old Aug 2, 2017 | 10:24 AM
MARANT23's Avatar
8th Gear
Default SoCalLR2
I saw the plug what goes to the Haldex Unit, that's the one I disconnected and the rubbing sound are gone, as soon as I connect agein the messages goes and the rubbing sound comes back,
my cuestion is the Haldex need 2 be connected, the car sound fine whit it disconnected 2 me, but I am no mechanic so I don't now if I am doing some damage 2 the car by having it disconnected
Old Aug 2, 2017 | 11:16 AM
SoCalLR2's Avatar
Oh, I see. I didn't understand your original post. I don't know for sure but I have read on other forums that you essentially turn it into a 2WD car when you disconnect it. Whether or not that will cause damage is unclear to me.
Old Aug 2, 2017 | 01:16 PM
MARANT23's Avatar
8th Gear
Ok, thank you, y just needed som info before going 2 my local STEALERSHIP
Old Aug 2, 2017 | 01:28 PM
SoCalLR2's Avatar
Good luck and be sure to report back so others can gain from your experiences.
2k2wranglerx
Audio/Visual Electronics
Mar 22, 2006 04:55 PM
beavis4g63t
Mar 14, 2006 02:55 PM
jaredkelly411
Mar 1, 2006 10:25 AM
JKK
Sep 18, 2005 09:33 PM
brunettc
Aug 8, 2005 07:31 AM
