Heated seats weak
Old Mar 30, 2017 | 09:40 PM
Heidi0613's Avatar
Default Heated seats weak
Hello all. I might as well give some back story on this one. I had the dreaded alternator drive coupler come loose on my lr2. My wife parked it in the garage as she was able to drive it home before the battery drained but she left the key pushed into the ignition and it say for a week and the battery completely drained. Anyway, I ended up replacing the alternator as I had to take the intake off anyway (150000kms) and repaired the loose coupler. Vehicle is back on the road now but both heated seats are very week and I can only reprogram two windows to roll up automatically. The battery light did come on a few times after the alternator was replaced but doesn't now ( I spilled some coolant whole hooking up the engine vent hose). Any reason why both seats are weak?
Old Apr 1, 2017 | 10:10 AM
LR Techniker's Avatar
I would try and find out why the alternator light occasionally comes on. Most cars today have a very "smart" power management system and I suspect that if the car thinks the battery is weak or the alternator output is less than desirable, it can actually reduce or disable some features.
We see this a bunch on BMWs. Cars w/ recent battery replacements will come in because certain features won't work and the A/C fan blows at 50%. Registering the battery in the power module restores those functions.
I can't find it in print that the LR2 does the same, but I do know that I have done Batteries in LR2s and when hooked up to the factory diagnostics, there was a "battery replacement" special function.
Its just a guess, hard to say without seeing the vehicle.
The picture below is for a L322 (full size) but the LR2 had similar
Old Apr 7, 2017 | 07:45 AM
jlrvkohl's Avatar
what year is your LR2? if it has a battery monitoring system then you will need to have the battery replacement function ran at the dealer. basically what can happen is vehicle will still think that the previous bad battery is in and will limit certain functions to save and distribute power to the more important functions
weeped
Feb 13, 2016 01:16 PM
booper169
Nov 9, 2010 09:10 AM
sydneysport
Oct 1, 2006 09:18 PM
sydneysport
Sep 24, 2006 11:33 AM
