Homelink buttons on rear view mirror
Old Mar 31, 2024 | 05:18 PM
guy's Avatar
guy
Default Homelink buttons on rear view mirror
Greetings All!
I will be posting on a few forums as I’m not certain we have the same readership on each.
The homelink buttons on the rear view mirror of the LR2 do not operate at all. No flashing led whatsoever, no matter what the operation.
Furthermore, the garage door does not even recognize any signal from only my LR2.
I have been all through the Owners Manual. I cannot find any reference to the appropriate fuse.
I have been through the electrical guide…. but it is the guide for the earlier version of lr2 and there are so many differences.
I have also tried the age old sledge hammer fix of a proper system reset.
All to no avail. Does anyone have any ideas?
Thanks.
Cheers!
Old Apr 1, 2024 | 06:41 AM
guy's Avatar
guy
I just learned its fuse F12 in the glove box. Yes, the same fuse as the reverse lights.
Cheers!
Old Apr 5, 2024 | 11:30 AM
curb-optional's Avatar
Cheers!
Maybe that's why my homelink button doesn't work! Mine worked for the first few years, but then when I changed garage door motors, forget it, never worked again. I tried a number of times to reset the button, but nope, not going to happen. Oh well.
Old Apr 6, 2024 | 07:22 AM
DougieB's Avatar
Default Signal
Are you certain that your transmitter is powered up properly and that you’re actually transmitting a signal? Not a good sign that the lights are out, in general. Mine doesn’t have homelink, but I’m guessing either a bad connection, bad circuit board/component, or a short. If you haven’t already, check all the mirror wiring connections. Use a multimeter to check every fuse in the vehicle. I’m sure you know there’s several fusebox locations.
Good luck and let us know what happens.
Greetings All!
Thanks.
Cheers!
GavinC
Mar 12, 2026 04:05 PM
okdiscoguy
Jan 16, 2024 04:31 PM
Defendit..
Feb 20, 2023 01:11 AM
