Hood open / Alarm
Old Nov 19, 2013 | 02:55 PM
Fattbastard's Avatar
I saw you mention an immobilization from a dead battery jump... i have a 96 LRD That was given to me with a dead battery. I cant justify a new battery unless i get it running, so i use a set of jumper cables to try and start it.
I have tried several times to start it and set the alarm off a couple times, and with the hood switch up...(didnt k.ow.a out it until later).
Any thougbts?
Old Jun 18, 2014 | 10:10 AM
capybaras's Avatar
3rd Gear
I also had false hood open problems, which was made worse when it was locked (alarm all going off all the time). I just unplugged the sensor and looped it as suggested, problem solved.
Old Feb 13, 2023 | 02:09 PM
Jason Ford's Avatar
7th Gear
Default Hood open/alarm
Originally Posted by depeche
Greetings,
A couple of times a week, my alarm goes off because it senses that the hood is open. The hood is firmly latched. Opening and closing the hood seems to solve the issue.
Has anyone had this problem before? Is there any sort of adjustment that can be made for whatever is sensing the hood latch open/close position?
This is on a 2008 LR2 HSE
Thanks!
we have the same issue with our 2008 LR2. Daughter currently has it at the U of Toledo. She can’t lock the doors since it goes off within 5 minutes. The vehicle was just broken into on campus in the athletic dorm parking lot, fortunately her golf clubs were in her locker at the golf facility. Hard for me to fix it since I live in Georgia and she’s at school in Ohio
Old Feb 13, 2023 | 02:38 PM
LR2driver's Avatar
Attached is the TSB with replacement instructions.
File Type: pdf
Old Feb 13, 2023 | 04:56 PM
flybd5's Avatar
I used a paper clip to jumper the contacts. Done.
Old Feb 13, 2023 | 05:03 PM
p_gill's Avatar
https://www.freel2.com/forum/topic38...=bonnet+switch
Good luck
Paul
Old Feb 13, 2023 | 05:58 PM
Jason Ford's Avatar
7th Gear
Default Tsb
does that mean the dealer will fix for free or do I need to have this resolved out of pocket?
Jason
Old Feb 13, 2023 | 06:14 PM
merlinj79's Avatar
Jason
A TSB is not a recall. If it's out of warranty, I'm sure you'll have to pay for it. But almost anyone can DIY this one... especially since the dealer will probably charge $1k.
I actually replaced the switch, but if it was just me I'd have jumpered the connector. But my wife might actually drive away with the hood unlatched. On one of those exceptionally rare occasions when she actually checks the oil.
Old Feb 15, 2023 | 06:22 PM
flybd5's Avatar
Wow. Don't trade her in, that is rare!
Old Sep 18, 2023 | 05:38 PM
Anon29871's Avatar
Default Can you take a picture on how you did it ??? I'm trying to do the same
