LR2 it cranks but will not start
Old Jun 19, 2020 | 07:27 AM
Jchahine's Avatar
4th Gear
Default LR2 it cranks but will not start
I have land rover 2012 LR2 116,000 km. when I fill-up the gas tank to the top the engine will shut off if not immediately
after I driving it 2 or 3 kilometres the engine shutoff but itself and will not start until after some cranking attempts or leave it off for 5 minutes and try crank it again
NOTE: The Battery is new
please help
Old Jun 22, 2020 | 02:55 PM
merlinj79's Avatar
Might be the fuel pressure regulator.
Get a code reader like this one, and pull your codes. That will probably narrow it down.
https://www.harborfreight.com/OBD-II...xoCM9UQAvD_BwE
Old Jun 22, 2020 | 04:00 PM
p_gill's Avatar
I am assuming that you don't have keyless ignition.
If you have to insert the key into the slot then please answer the following question.
Do you leave the key docked while fueling?
Old Jun 22, 2020 | 06:08 PM
flybd5's Avatar
Otherwise known as "If it hurts, don't do that!"
Jchahine
LR2
22
May 22, 2020 12:12 AM
Shannon Skipper
LR2
Nov 13, 2019 08:45 AM
mgoug
Jan 27, 2013 06:47 PM
drzjoint
LR2
May 21, 2009 07:04 AM
lotek10101
LR2
Aug 20, 2008 07:23 PM
