LR2 Rear Differential Bearing Failure 69k Miles
Old Sep 14, 2019 | 01:13 PM
  #21
kind16's Avatar
6th Gear
Originally Posted by oliver1071
If this is the result of a poor maintenance schedule listed in the manual since the vehicle is using a haldex differential then I don't see the failures being resolved. But if you can get one with low miles 20-40k and do the maintenance early I would say that it's fine. Haldex isn't a bad system you just need to stay on top of the fluid changes and they will last forever. Or if they've updated the manual for a lower maintenance interval and your seller has records then it would also be good.
I'm not familiar with the newer models.
Thank you for the prompt reply, saw some videos, it it quite easy to change the rear diff oil, just need a syringe to suck the oil out and fill it with new one, I can do it once every 2 years. Thanks.
Old Sep 15, 2019 | 11:01 AM
  #22
merlinj79's Avatar
Originally Posted by kind16
am thinking of buying a 2013-2015 LR2, are the rear diff issues still there in there LR2s?
I'm pretty sure in the later models they fixed the rear diff bearing problem which caused the diffs to fail at 30-80K miles.
But what I would do is change the rear diff and front transfer case fluid immediately, and also do the Haldex service which LR does not consider necessary. Then incorporate aggressive regular maintenance for the Diff, Haldex, and front transfer case (PTU). Much more frequently than LR suggests.
Old Oct 16, 2019 | 08:18 PM
  #23
Jill Cash Anderson's Avatar
No they have not. I have a 2015 LR2. It's in for a new rear end, fortunately I bought a CPO. I just rolled 80k. I've replaced the turbo, 3 fuel injectors, alternator and all the tire sensors. That's what I can think of off hand. Absolutely love my Land Rover but would never buy one without being certified.
TheReverend
LR2
Feb 6, 2014 02:11 PM
GoodLife23
LR2
Feb 16, 2013 12:08 AM
Muscat
LR2
Dec 6, 2011 11:44 PM
lin8810
LR2
Jul 24, 2008 05:51 PM
