LR2 Strut Replacement
Old Dec 8, 2020 | 02:38 PM
UP49802's Avatar
Default LR2 Strut Replacement
Hello All!!
I am about to replace the struts on my 08 LR2... It seems as if the front insulator (LR018785) contains the bearing as well? Do these normally fail or can they be used over again. The steering is smooth with no "memory" or binding. I assumed that the bearing would be contained in the mount but that doesnt seem to be the case. Please Advise ???
Old Dec 8, 2020 | 05:03 PM
flybd5's Avatar
Maybe this helps. I don't know what you mean by "insulator".
Old Dec 8, 2020 | 05:06 PM
UP49802's Avatar
It appears to be contained/pivots on #6. I am doing some round and round interchanging part numbers and it appears that Volvo used the same part on XC70 and XC60
Old Dec 8, 2020 | 05:08 PM
flybd5's Avatar
The service manual does not say anything about discarding the bearing when replacing the strut. It is intended to prevent the spring from winding up during actuation. If you have no symptoms, I would leave it be and reuse it.
UP49802's Avatar
Ive been a auto parts, heavy duty parts, frac equipment parts guy for 30+ years... Just new to the Landy world
Old Dec 8, 2020 | 05:12 PM
UP49802's Avatar
OK great!!! I just was worried that I possibly could create a "dead horse" in the stall! Which doesn't EVER make friends when your sneaking in and doing work! LMAO ... Thank you so very much!! I cant wait to see how it drive with the new Bilstein B4 on all 4 corners!!!
Old Dec 8, 2020 | 05:14 PM
flybd5's Avatar
Good luck!
Old Dec 10, 2020 | 12:14 PM
ThorInc's Avatar
I am going to proactively replace my front struts with Billys as well. I did the back with Billys a while back because the DS was leaking. You might want o get the item 9, the spring isolators, I did; I also purchased two insulator bearings to replace at the same time but it's most likely an unnecessary step. I'll update this thread on the condition of the original bearings once I do the job. p_gill posted this video link elsewhere:
Old Jan 3, 2021 | 05:20 PM
UP49802's Avatar
Well.... Got struts on... Went ok except for the cracked bottom coil on front spring. Had a set flown in overnight. What a difference in ride quality. LOVE the Bilstein B4's. Got power steering fluid changed out with the CH202. Only thing left is the trans fluid and brake fluid flush. I got a set of Summimoto Ice Edge and they are simply AMAZING. Even on ice/hardpack snow I havent even slipped so far. Did a 55mph panic stop and very controlled/straight with only a second of antilock brakes. LOVE LOVE them. Went with 255/55/18 size.
ErsatzCucumber
LR2
Sep 18, 2020 07:03 PM
kind16
LR2
Sep 15, 2019 01:00 PM
drzjoint
LR2
May 21, 2009 07:04 AM
05LandRover
Freelander
Dec 18, 2006 04:17 AM
